Windshield Washer Fluid Pump
Old 04-14-2018, 03:51 PM
UWZerokoolX's Avatar
Okay, I cannot justify buying an entirely new forty dollar Windshield Washer Pump just for the rubber gromet that seals it to the windshield washer resvoir. Does anyone have a part number for the rubber gromet?
UWZerokoolX is offline
Old 04-14-2018, 04:03 PM
Read post number 8, while this may or may not correct your issue , hey it’s inexpensive and may save you a few bucks.
https://www.chevyhhr.net/forums/main...eak-fix-54278/
Oldblue is offline
Technical Moderator
Usually it is the internal seal that fails, especially in freezing weather, that looks like the grommet is leaking.
You would probably have to go to a store that has jobber boxes to match one up. Bad news is not all new pumps come with a new gasket.
They can be had for closer to $30. https://www.ebay.com/itm/ACDelco-193...tWqOzJ&vxp=mtr
donbrew is offline
Old 04-14-2018, 04:08 PM
Yeah I just got done reading that blue. I was hoping that someone would come up with a part number by now.
And don't you worry don, I am not going to wig out on you.
I might as well do the simple cheap fix... I already have my air intake hose duct taped because I cant find the part number for that either. -_- *Deskface* argh!
Old 04-14-2018, 04:16 PM
Technical Moderator
You might try
a. looking in the part number thread
b. looking at an online GM parts store like this: https://www.gmpartsgiant.com/parts-l...ke-system.html
donbrew is offline
Old 04-14-2018, 04:17 PM
Air intake duct hose, commonly called the Woolley Worm.
One solution
https://www.chevyhhr.net/forums/prob...problem-53013/
Wolley worm part number in post #9 here
https://www.chevyhhr.net/forums/main...cleaner-58572/
Oldblue is offline
Old 04-14-2018, 04:21 PM
https://www.chevyhhr.net/forums/comm...33/#post791993
RJ_RS_SS_350 is offline
Old 04-20-2018, 02:01 PM
4silverado's Avatar
I don't know if this helps, but I picked up a 2011 back in January. It would dump washer fluid on the ground faster than you could dump it in. I removed the reservoir thinking that it might be cracked; the pump grommet was bad. I wiped everything down and applied a liberal amount of blue silicone and put everything back together. I waited a full week before adding fluid. So far, it's holding fluid with no issues.
4silverado is offline
knelson1969
Maintenance and Upkeep
10
03-31-2017 08:10 AM
gio89kid
12-12-2015 07:54 PM
phenderson51
01-21-2014 02:46 PM
Jeff®
09-01-2013 10:32 PM
Quick Reply: Windshield Washer Fluid Pump
