08 HHR SS CV Axle
I actually ended up going to o reillys to grab the gm8206 shafts. I had them pull the bearing set for the car and fitted the shaft perfectly into it. The shaft is made for the malibu I believe. Benn running them for awhile now and they have been working fine, even on my 425 hp hhr
Help me brothers
Hi Jeff, to the forums!
The axles are the same from one side to the other. The manual transmission uses a different shaft than the automatic. Here is the discussion about SS axle shafts.
https://www.chevyhhr.net/forums/www....ad.php?t=57070
