2010 LT Axle Spindle Size
Old 09-08-2018, 12:34 PM
Hi! I'm working on replacing a bearing, and went to buy an axle spindle nut. A parts store sold me an M20 nut that just slid over the threads of the spindle, and others online list the same size. The OD of the threads on both front axles measures around 19mm. Could these be aftermarket CV shafts, or should I be looking for a different size spindle nut? Thanks in advance...
C3P0 is offline
Old 09-08-2018, 12:42 PM
Mine is an LS , the nut takes a 30 mm socket about 19 mm threads
https://www.rockauto.com/en/catalog/...indle+nut,1616
Oldblue is offline
Old 09-08-2018, 01:08 PM
Originally Posted by C3P0 View Post
The OD of the threads on both front axles measures around 19mm. Could these be aftermarket CV shafts, or should I be looking for a different size spindle nut? .
Could be. Or your the nut you bought was wrong.
https://www.rockauto.com/en/moreinfo...=1444617&jsn=9
Cat Man HHR is offline
Old 09-08-2018, 04:09 PM
Oldblue, Cat Man, thanks for the pointers! These on the car have a 30mm nut size also, so I'm thinking the guy just gave me the wrong one (it was not packaged, just got it out of a bin and said "Here ya go!"). I've got one on order at this point, hope they deliver the right one.
Cheers!
C3P0 is offline
Old 09-08-2018, 04:26 PM
Technical Moderator
One set of axles I got had a different wrench size nut included, same thread though. I have reused the nut and am alive to tell about it, as many others have (most shops reuse)
donbrew is offline
Old 09-08-2018, 05:36 PM
If the new hub comes with the nut, fine I’ll use the new nut but I have reused axle nuts when I didn’t have a new one.
Oldblue is offline
Old 09-13-2018, 07:51 PM
Thanks again, guys. I'll be diving into this Sat. morning, lost too much time last weekend to get 'er done. Will update...
C3P0 is offline
maddawg
08-12-2014 10:21 PM
Nazramoth
06-08-2014 03:05 PM
8t7vette
08-02-2010 02:09 PM
zhris
04-27-2007 12:38 AM
Quick Reply: 2010 LT Axle Spindle Size
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
