Can't Access Upper Transmission mount bolts
Old Jun 6, 2021 | 12:25 PM
JamieCook's Avatar
I'm having trouble getting access to the upper transmission mount on the drivers side fender. Do I need to remove/ disconnect the fuse box/computer to gain access or is there an easier way to access the bolts to replace the mount? Any help would be appreciated. thank you
Old Jun 6, 2021 | 12:50 PM
Move the fuse box , just undo the mounting fasteners and gently move it! Oh, very important, disconnect the negative terminal at the battery!! First!
Oldblue
Feb 28, 2026 08:04 PM
chevyenvy
Oct 12, 2024 04:55 PM
largojuan53
Maintenance and Upkeep
7
Jan 2, 2022 05:57 PM
bassbase
2.4L Performance Tech
26
Jun 28, 2019 10:42 PM
hhrokie
Feb 12, 2013 04:42 PM
