Transmission
Old 01-22-2018, 12:03 PM
Old Lar's Avatar
Transmission
I had a friend ask me how well the HHR transmission held up. Although my 06 was traded away in 2015 with 133,000 miles on the clock I had no issues with my transmission. His HHR has more mileage and has been used as a delivery car. He was debating on repairing which may cost $2000(?) or replacing the car ($15,000). Any ideas?
Old Lar is offline
Old 01-22-2018, 12:33 PM
Technical Moderator
Both of mine were used for delivery work and the trans was the very last of my worries at over 300K.
My math says repair; even adding a new motor(about $5,000) and completely overhaul the suspension (about $2,000) is less than new. A courier needs to keep cost close to zero, he would need to save a lot on gas cost to make up the difference.
donbrew is offline
Old 01-22-2018, 01:31 PM
I’m over 250,000 miles , no transmission problems, I’m with Don, rebuild the transmission
Oldblue is offline
Old 01-22-2018, 08:05 PM
hellshotrod's Avatar
there are plenty of low mile parts out there just find a honest repair shop i charge 300. labor to r & r a motor or trans , plus cost of the parts so its not that bad and they are very easy to do ,
hellshotrod is offline
Old 01-22-2018, 11:30 PM
I'd do a swap as per hellshotrod - I bet a repair will be a lot more than $2K.
whopper is offline
DJ Koz
2.2L Performance Tech
11
08-21-2006 11:58 AM
Heartbeat
2.4L Performance Tech
08-15-2006 08:51 PM
calgaryhhr
07-29-2006 02:24 PM
BryceStrong
16
07-18-2006 06:42 AM
nabate
05-22-2006 10:36 AM
Quick Reply: Transmission
