CV shaft inner joint issue
Old Jan 11, 2020 | 06:10 PM
Mirrorimage518's Avatar
Any chance that the old bushing is still inside the transmission and the new shaft came with a new bushing and you're trying to install 2 bushings where there should only be 1 ? The extra bushing would be riding right where the seal is and could be the cause of the damage.
I'm not implying this is sure thing, but we've all had our own "Duh" moments when working on cars.
anything is possible in the automotive world. I don’t think it’s the case here though. I’m tryin to find a used tranny to get a picture of before I start ripping on things haha.
Old Jan 11, 2020 | 07:18 PM
Well, it isn't supposed to be there. The sleeve on the stub is supposed to go through the seal all the way.
If you took the stub shaft off the axle and installed it would look just like the driver side.
Old Jan 12, 2020 | 12:49 AM
Looking at your post #2, it looks like the there is contact with the bolt below the opening. I'll ask again, what part numbers are you using?
Old Jan 12, 2020 | 08:49 AM
Passenger side cv shaft part number
Seal kit part number
Old Jan 12, 2020 | 09:11 AM
Cat Man HHR's Avatar
Don. Pretty sure the foreign object you mention is the pin in the ring and pinion (or whatever the correct name is)
Looks like a spider gear setup like you would have in a differential.
Old Jan 12, 2020 | 09:35 AM
  #26
No CV installed. Stub shaft is “clipped in.” Can’t get the seal in any further as it hits the inner steel race. Also as you can see the shaft is pulling down on the seal causing the gap on the top of the seal. Everything in installed the two seals got perfect together. Fairly snug fit (no gap.) anyone know how much play is considered “okay” on that transmission output shaft??
Old Jan 12, 2020 | 10:53 AM
  #27
Looks like it is not installed fully, like this
Old Jan 12, 2020 | 11:08 AM
  #28
That is the drivers side in your picture. But this is my issue. I physically can’t slide in the stub shaft seal any further without hitting the internal steel raceway/sleeve.
Old Jan 13, 2020 | 04:22 AM
  #29
How much more does it have to go in ?
Are you talking 1/8 inch ?
You could sand down the back of it.
Use a flat plate, use contact glue spray and put fine aluminium oxide paper on it and work the piece in a figure 8 to bring the size down.
Just a thought.
Old Jan 13, 2020 | 08:19 AM
  #30
2 seals?
