Difference between early/late '08 transmission
Old Apr 26, 2022 | 02:40 PM
Psyclopse's Avatar
I have a 2008 HHR (2.2 auto) with a bad transmission. I have already removed the transmission and I'm ready to buy a replacement. Most places want me to choose between "through 1/06/08" and "from 1/07/08." I know my car was manufactured 9/07, so I know which category I fall into. My question is- What was changed, and what would it take to be able to use the later transmission?
Thanks.
Old Apr 26, 2022 | 03:02 PM
Welcome to the site, only differences I can find are gear ratio in the final drive. That’s not to say there’s any difference in the TCM to control the shifts . As far as I know CV axles shafts are same , mounts are same, bolt pattern for the bellhousing are the same.
I would stay with your production range and get as low a mileage as possible.
Old Apr 27, 2022 | 09:50 PM
Psyclopse's Avatar
Thank you for the quick reply. I did locate the appropriate transmission local to me, so I'll be picking it up tomorrow.
Old Apr 28, 2022 | 03:03 AM
PulpFriction's Avatar
Pretty sure 2.2 and 2.4 got different ratios so ask about that.
Old May 4, 2022 | 11:24 PM
Psyclopse's Avatar
The transmission I bought came from a 2.2 car, so no worries there.
Got the transmission installed, new filter, flushed the cooler, and everything put back together. Everything was good to go right off the bat!
Now I'm off to tackle what seems to be some common issues (after reading through the forum here) such as dead speakers and a floppy sun visor. This site is a goldmine of information.
Old May 5, 2022 | 07:03 AM
We aim to please! Now which speakers to get and where? Let us know!
Garyroe75
2.2L Performance Tech
10
Apr 19, 2022 10:08 PM
will1528
Jan 2, 2021 04:57 PM
soccerjunky
Nov 30, 2008 09:54 PM
millpond2
Dec 30, 2007 02:02 PM
