F23 Rebuild Kit/synchros
Hello All,
I have a 2010 HHR 2.2L with the F23 getrag and am in need of a rebuild kit or at least the parts. Long story short, have two transmissions that need fixed. One needs main shaft bearings as it has an ear piercing wine in all gears and the other needs 3rd/4th synchro as it grinds going into both gears and they are on the same shaft. I like the car too much to get rid of it. Does anyone know where I can get parts for these transmissions?
https://transpartswarehouse.com/stan...g/kits-64.html
I just googled F23 rebuild kit , lotsa sites have kits available
This might be a better solution
https://store.dfkitcar.com/products/...3-transmission
Brand new! Give them a call
I did just buy one of those last night. I still would like to rebuild one of these transmissions if not both to have one spare at the minimum. Those kits on the link you have appeared to be for the NV3500 trans. So I'm guessing then there isn't a place to source parts other then trying to see if the dealer can get them?
camaro98z28
2.0L Performance Tech
12
May 27, 2010 09:05 PM
