Half shaft Seal
I will be replacing a Half shaft soon, does anyone know the part number for the trans seal? I would like to get on in the event I tear it up removing the shaft.
I have done a few and never damaged the seal.
Have you looked at GMpartsdirect.com or any of the online GM parts sites? Most have part numbers with illustrations. |
Originally Posted by DrLoch
(Post 769215)
Auto transmissions in the LS, LT and SS are the same, but the 5 speed LS and LT trans. are different from the SS 5 speed. There may be different seals, so without your vehicle info it's hard to give a part number. |
(Post 769231)
Need your vehicle info.
Auto transmissions in the LS, LT and SS are the same, but the 5 speed LS and LT trans. are different from the SS 5 speed. There may be different seals, so without your vehicle info it's hard to give a part number. 2008 SS 5 speed Tried gmpartsdirect, didn't see a parts breakdown. |
for 2008 to 2011 F35 5 speed seal ,check out Carid at
National® 3543 - Chevy HHR 2008-2011 Manual Transmission Output Shaft Seal |
Thank you
You are welcome, I'd replace both at that price
| All times are GMT -5. The time now is 05:43 AM. |
