HHR Making a New Noise
Old Jul 17, 2016 | 01:36 PM
Yes I did.
Old Jul 17, 2016 | 04:02 PM
By design Impact sockets are a bit loose, not enough to slip.
Old Aug 7, 2016 | 09:00 PM
BigT's Avatar
OK, I got a pair of front bearing hubs with ABS, a couple of new axil nuts and a 30mm deep socket. I determined that it is the front passenger side bearing. I will do that one tomorrow and worry about the other one later.
Old Aug 8, 2016 | 10:04 AM
don't wait to long, they tend to fail in pairs! And a tip break the axle nuts loose before you jack up the car! unless you have aluminum rims. the socket won't fit thru the center hole
Old Aug 8, 2016 | 03:59 PM
BigT's Avatar
I got the bad one replaced today. It took about 2 hours including clean up, nothing was stuck. Sounds good now. Thanks for all the help I got from the forum members. I'll get to the other one Soon.
Old Aug 8, 2016 | 06:03 PM
Don't forget to retorque the axle nut and lug nuts after say 100 miles or so!
twilliams3269
Jan 9, 2015 09:50 AM
simonb
Apr 27, 2014 07:58 PM
colzdad
Mar 22, 2014 06:46 PM
snoopyspaz
55
Aug 22, 2011 05:45 PM
camaro98z28
Oct 21, 2009 02:49 PM
