Key Will not turn off.. shifter or ign switch???
So, the 2009 HHR will not turn off. I read about the shifter switch and assumed that was it. Here is my question, though. When I push the plunger for the key release it does not release the key to turn. I pulled a fuse and the battery to shut it off. so the question is is it the shifter switch or is it the ignition switch??? the fact that the key wont release is confusing me.....
Originally Posted by floridamisfit
(Post 711867)
(Post 711867)
Thats what my Chevy tech did to get mine to work and then ordered a new shifter mechanizm. |
ok thanks guys. just wanted to make sure before I drop the $$$ on a shifter
Sounds exactly like mine, and it was the ignition cylinder.
Originally Posted by prod
(Post 711886)
1. The ignition switch 2. The ignition lock mechanism Both are actuated when you put the key in the ignition switch but they have different functions. I can only assume they might be integrated into one replacement part but it sounded like they were dealt with separately for warranty. SF |
(Post 711886)
(Post 711867)
Thank you, Jessica L. Chevrolet Customer Care |
(Post 711896)
did you fix it yourself??? is there a way to test the ign cylinder???
