I replaced the slave cylinder on the new trans just in case, since it was sitting for a long time at the junkyard.
Here is a picture of the old slave cylinder:
The new slave cylinder mounted on the transmission:
And I also replaced the two axle seals. The seals have a raised dome, so you can't just used a flat drift to pound them in. I found that a piece of 2" diameter steel water pipe fit perfectly.
cry of delight!
titanic efforts, you are just a hero of labor!
you can eliminate other damages and breakdowns, you still took apart half the car. Good reason not to go there twice.
Enough no-seize on the cradle bolts to look like we were frosting a cake.
Added the 1.9 quarts of Dexron VI to the trans and bled the clutch.
74 lb-ft + 180 degrees is a LOT of torque (on the cradle bolts). Interestingly, the flange nut (that replaced the broken cage nut) didn't try to rotate much as I tightened the bolt. I was afraid the wrench holding the nut would end up jammed tightly against some body or steering rack part, but no problems.
The car is much easier to drive with 2nd and 3rd gear available
Everything seems to be working well and the car drives very well.
Now I want to disassemble the old trans to see why 2nd and 3rd failed.
