replacing 4T45E harness - need to remove valve body?
Old Sep 14, 2024 | 05:15 PM
KD2DHP's Avatar
I'm getting ready to pull the side cover off my trans to replace my solenoids, pressure switch and harness. I was looking at the procedure on alldata and it indicates the entire valve body needs to come off in order to remove the connector housing from the transaxle case. Since that would mean I'd need to replace the valve body mounting gasket, I'd rather wait until I have it on hand before I tear into it. Can anyone confirm this?
The info also indicates that a special tool is needed to remove the connector, but I'd guess that one of my harbor freight picks would probably do the job.
Old Sep 14, 2024 | 11:14 PM
Why are you replacing the internal harness? If you are just replacing solenoids unplug one at a time
Old Sep 15, 2024 | 09:04 AM
You can replace the whole valve body or just the solenoids
https://www.chevyhhr.net/forums/driv...olenoid-61313/
New to me HHR
Nov 3, 2021 03:34 PM
hhr06NJ
2.2L Performance Tech
Oct 2, 2014 08:42 PM
fernando pena
Sep 16, 2012 04:06 PM
asanti
May 29, 2011 03:29 AM
XXL
Dec 29, 2009 07:22 PM
