Shift Solenoid
Old Feb 12, 2020 | 05:58 PM
  #81
wokbelly's Avatar
Originally Posted by NightmareHHR
Hello all, I am finally joining the site after reading it for some time now. This is an epic thread and certainly deserved becoming a sticky. I have just completed this on my 2011. Much like the last guy (his issue, not attitude ) I have a transmission that wants to go forward in all shift positions. It shifted fine before repair. I had the P0700 and P0842 combo plate. I decided to replace the pressure switch manifold, pressure control solenoid, and both shift solenoids. I also replaced the trans pan and filter. My question is; does anyone think I may have reversed the plugs between the two solenoids? I have checked all of my external connections and fluid level. Any input would be greatly appreciated.
I know this is after the fact for you but the best thing to do in these situations is take lots of pictures which relly easy with a cell phone nowdays cause then you see exactly what you may have done wrong it helped me alot with my repair if you dont know already the shifting solenoids are just for that only so i doubt that would make the car want to travel so its some other area not the shifting solenoids they are identilcel unfortunatly thats all i replaced in mine so look at the others maybe thats the problem sorry cant be more help for ya
Old Feb 12, 2020 | 06:34 PM
  #82
That's a tough read. You should try the comma and period buttons, down to the right of the space bar. Or if you're using talk-to-text, you can just say "comma" or "period" at the appropriate times.
Old Apr 27, 2021 | 09:05 PM
  #83
Murph's Avatar
Old Oct 31, 2021 | 07:39 AM
  #84
glassdave's Avatar
quick question about this process. Are you dropping/tilting the engine/trans a few inches and then dropping/tilting the engine cradle a few more? Thanks, getting ready to tackle mine in a few.
Any chance you have a complete list of parts used? thanks
Old Oct 31, 2021 | 08:51 AM
  #85
There’s photos starting at post #25 or 26, Steve has explained his parts on page 1 it’s not in a grocery list per say, but he does list his parts and fluids.
Old Oct 31, 2021 | 11:26 AM
  #86
glassdave's Avatar
ahh, ok musta missed that i will go back and look
Old Oct 30, 2023 | 05:42 PM
  #87
Recovry4x4's Avatar
Sorry to resurrect an old thread but trying to keep the pertinent info together. I am in the midst of doing solenoids on one of my HHRs. After going through my factory service manual and reading this thread repeatedly, I have a question. Since I plan on following the OP lead, I'll drop the drivers side of the engine down enough to access top bolts and the cradle a few more inches to access the bottom bolts. Looking at the shift cable and such, I can't figure out why it needs to be disconnected. There is plenty of slack for it to move. Can't I just unplug the PNP?
Old Oct 30, 2023 | 05:48 PM
  #88
glassdave's Avatar
Been a while since i did mine but i dont think there actually was enough slack to leave it connected, plus the more you get out of the way the better. I think somewhere in the instructions there was something about resetting or adjusting something with the cable but i just popped mine off and put it back on no prob. Maybe others will chime in on the though. Good luck it was pretty intimidating when i started but in the end it really wasnt to bad and truth be told i feel i can do the whole thing start to finish in about two or three hours now that i know (on a clean rust free car)
Old May 9, 2024 | 11:00 PM
  #89
SuKi's Avatar
Steve,
I replaced my shift solenoids today and just wanted to say thank you for your posts in this thread. They were extremely helpful and saved me at least a few hundred dollars while doing it myself instead of paying a shop to do it.
Old May 13, 2024 | 12:38 PM
  #90
arieswess1982's Avatar
Now imagine doin all that, not 1x but 2x, and she drives forward in reverse... hope it's the park neutral switch... fingers crossed, on mo 5, goin on 6, to many parts replaced to list... 4k in parts tho...
