Traction control
Old Dec 11, 2013 | 04:04 PM
Lucky's Avatar
Originally Posted by Frenchy42
Hmmm... I'm not completely familiar with how the HHR TCS systems work, but it may be that it applies the brakes to whichever wheel is slipping. personally, I'm with CJ, i always turn my TCS off, ESPECIALLY when it's raining or snowing.
You are correct the abs noise is normal because it's using the abs to apply brakes to the wheel that's is sipping in hope that the power will be transfured to the non slipping wheel. When slipping on ice the traction control go's nuts because it can't find a wheel with traction to transfer too. So yes when it's really bad out your better off to turn off the traction control. The traction control works well one wheel may be stuck in snow/mud and the other drive wheel is not so the power can be transfered to that wheel and pull you out.
Old Dec 12, 2013 | 03:27 PM
Sounds like catncarp needs an Owner Manual. Use the SEARCH box at the top of this page, type "Owner Manual". Ignore the top paid ads.
Jmilatz
Jul 24, 2014 05:21 PM
bowlerswife
Oct 19, 2013 10:45 PM
Speedrazer69
Jul 29, 2013 11:31 AM
Money in the Bank
Oct 19, 2007 12:26 AM
Whichfinger
Jul 22, 2006 11:30 AM
