P0700 and P0741
Old 03-07-2016, 10:32 PM
Wifes07LT's Avatar
P0700 and P0741
Hey everyone, the other day, I was driving my wife's 07 LT 2.2 (129k miles) and the check engine light came on. I scanned it and got:
P0700- Transmission control system mil request
and
P0741- torque converter clutch circuit performance or stuck off code.
I did notice a slight whining in the transmission in 3rd gear with light acceleration, and the transmission doesn't seem to be going into 4th gear. Does anybody know if this could be just a bad TCC solenoid, or am I going to need to overhaul this transmission?? Anybody have these symptoms and codes at all before?
Wifes07LT is offline
Old 03-07-2016, 10:33 PM
Wifes07LT's Avatar
Would a bad torque converter clutch solenoid cause the transmission not to shift into 4th gear?
Old 03-08-2016, 07:21 AM
Technical Moderator
YES, that is what 4th gear is.
The description is " torque converter clutch circuit performance or stuck off code", so it could possibly be a electrical thing.
donbrew is offline
Old 03-08-2016, 08:31 AM
It could also be chaffed wires or loose ground wires or TCM connection
Oldblue is offline
Old 03-08-2016, 04:14 PM
Wifes07LT's Avatar
Ya know? That's what I thought, but I am being told differently. I've heard it won't go into 4th with that solenoid bad, but I've also been told that the trans not going into 4th is a bigger problem than just a TCC solenoid.
I guess my plan of attack will be spend the $30 on the solenoid and change that first and see what happens.... worst case scenario, I'll rebuild it for $440, but I'd change out that solenoid either way, so all I'm wasting is time if I do the solenoid job and need to tear it down again
Old 03-08-2016, 05:09 PM
Technical Moderator
$30 for the part, $400 labor. You have to drop the entire cradle. I think R&R cradle is about 10 hours.
Gears 1-3 are inside the gearbox 4th gear is when the torque converter locks and the engine (basically) drives the wheel directly, overdrive.
donbrew is offline
Old 03-10-2016, 01:31 AM
Wifes07LT's Avatar
Nah! $30 for the part, $0 for the labor.... a day at the shop mother-f'ing Chevy as I tear it down and fix it myself!
Old 06-13-2018, 04:46 PM
Denise Destiny's Avatar
TCC solenoid
So did the TCC solenoid fix the issue?
Denise Destiny is offline
Old 06-13-2018, 04:52 PM
Welcome to the site, the OP hasn’t been back since 03/21/2016, so I doubt you will get an answer.
Oldblue is offline
George1
11-21-2017 06:22 AM
ImNewHere
07-31-2014 07:22 PM
clwest25
01-07-2014 07:54 AM
sbrice54
09-04-2013 01:42 PM
JACK VICTOR
03-04-2012 11:10 PM
Quick Reply: P0700 and P0741
