Transmission from a 2007 Cobalt?
Old Nov 20, 2024 | 07:07 AM
There is a stub shaft, you put the clip ring on it and slide the cv axle over it. It does just pull out with a quick tug.
https://www.chevyhhr.net/forums/driv...g-again-66133/
This kit fixed my situation it is designed for passenger side only .
Old Nov 20, 2024 | 08:08 AM
TruckerKevin's Avatar
That kit looks intriguing,,, did you have a lot of slop in yours? Obviously you did for the seal to leak. Did it tighten the slop up quite a bit? It’s a bit pricy but if it fixes the issue.
I did not seem to have an issue until I swapped the cv axle for a replacement. It was not a Detroit axle but some other off the wall brand on Amazon.
It’s a bit puzzling but I never had any leaks, only a noise like something is rubbing. That was my one and only warning before the axle popped out
Old Nov 20, 2024 | 08:20 AM
The kit tightened up the bearing sloppy movement that caused my seal leak. The Detroit axle will work for a seal leak but not the transmission bearing internal were the stub shaft lives
white08
2.4L Performance Tech
Mar 10, 2014 12:47 PM
RF2
Jan 12, 2014 08:36 PM
Tony_SS
Dec 19, 2009 07:59 PM
09_SS
Aug 10, 2009 09:04 PM
GDZHHR
2.2L Performance Tech
26
Aug 16, 2008 11:35 AM
