Transmission from a 2007 Cobalt?
There is a stub shaft, you put the clip ring on it and slide the cv axle over it. It does just pull out with a quick tug.
https://www.chevyhhr.net/forums/driv...g-again-66133/
This kit fixed my situation it is designed for passenger side only .
That kit looks intriguing,,, did you have a lot of slop in yours? Obviously you did for the seal to leak. Did it tighten the slop up quite a bit? It’s a bit pricy but if it fixes the issue.
I did not seem to have an issue until I swapped the cv axle for a replacement. It was not a Detroit axle but some other off the wall brand on Amazon.
It’s a bit puzzling but I never had any leaks, only a noise like something is rubbing. That was my one and only warning before the axle popped out
09_SS
Aug 10, 2009 09:04 PM
