Water dripping down on passenger side floor ....not from rain
AFTER RUNNING A/C ...ITS NOT DRAINING OUTSIDE ....MUST BE CLOGGED...ANYONE KNOW HOW TO RESOLVE OR HAVE THIS ISSUE BEFORE....THOUGHT OF SHOOTING AIR THROUGH DRAIN LINE IF i CAN FIND IT
2010 hhr |
Welcome to the site pindars. I don't know but I bet someone will come along who does.
:howdy: |
Compliments of Chevy Mngrs Postings-The Pictures are visable on POST 114 on the TSB THREAD
09-01-37-002a -------------------------------------------------------------------------------- #09-01-37-002A: Front and Rear Passenger Floor Carpet Wet (Inspect White Plug in HVAC Evaporator Drain and Apply Sealer to Front of Dash Area) - (Nov 3, 2009) Subject: Front and Rear Passenger Floor Carpet Wet (Inspect White Plug in HVAC Evaporator Drain and Apply Sealer to Front of Dash Area) Models: 2008-2010 Chevrolet Cobalt, HHR, Malibu 2008-2009 Pontiac G6 2008-2009 Saturn AURA --------------------------------------------------------------------------------------- Condition Some customers may comment that the front and rear floor carpet is wet on the passenger side. Cause This condition may be caused by a plugged HVAC evaporator Drain. In some cases, water from the HVAC system will drain back though the front of the dash. Correction Note: Reposition of the heat shield is not necessary on a Cobalt and HHR. 1. Verify the customer's concern. If there is water on the passenger side front floor area, raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in SI. 2. Inspect the operation of the drain. Note: Make sure that small debris is not plugging up the drain. 3. Reposition the heat shield (1) in order to gain access to the HVAC drain. 4. Remove the white plug (1) and assure there is no debris in the drain tube and/or plug. If debris exists, pull from the drain tube (do NOT force back into evaporator case) and reinstall the plug. Important: Do not get sealer on the heat shield, on the end of, or within the drain tube. 5. Mask off the areas (1, 2) by the HVAC drain using high-quality automotive tape. 6. Apply high tech seam sealer, Kent Industries P/N P6101*, to the front of dash area as shown in figure below. 7. Remove the high quality automotive tape and reposition the heat shield to it's normal position. 8. Lower the vehicle. Let the vehicle run with A/C on. Perform a final inspection for the A/C and verify that the system is draining properly. * We believe this source and their products to be reliable. There may be additional manufacturers of such products/materials. General Motors does not endorse, indicate any preference for, or assume any responsibility for the products or material from this firm or for any such items that may be available from other sources. Parts Information This product is currently available from Kent Industries (1-888-YES-KENT). Part Number Description P6101 HIGH - TECH BLACK SEAM SEALER |
clogged AC drain
does anyone have pics of the repair??
What repair? Read the first 2 lines of the post just before yours, if that's the repair you mean.
| All times are GMT -5. The time now is 07:07 AM. |
