Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
coasting
Old Jul 21, 2009 | 11:07 AM
catdaddy137's Avatar
coasting
i don't do it much , but i occasionally put the trans in neutral and coast down some hills....it does make a difference because even though i not giving it any gas , it revs more rpms when in gear...i'm sure the computer must be sending some gas......today i made what i thought was a really big and stupid move , i put it in reverse instead of neutral ......i guess the hrr has a switch that kills the engine , for idiots like me .....i pulled over and stopped expecting to find that i had damaged somthing....nope , as far as i can tell , nothing....all i can say is thanks to gm.
Old Jul 21, 2009 | 11:29 AM
twistrman's Avatar
good to know that is built in, ha.
i coast down a big hill on my way to work every single day, unless i am behind some slow person and i gotta ride the brakes. The hill is large and about a mile long, and as soon as i pop it into N, the instamatic mpg shoots up and i ride at 99 the whole way down. I sometimes forget when i get to the bottom though, and go to turn the corner and hit the gas and all i do is rev it...
Old Jul 21, 2009 | 07:57 PM
wxman's Avatar
On my trip to Colorado, the best mileage I got was going up and down the Rocky Mountains. I guess downhill helps a lot more than uphill hurts. I got 5 mph better there than on flat road.
Old Jul 21, 2009 | 08:03 PM
twistrman's Avatar
yeah i can see that. In my town it kills the mileage anyways. However the same hill in my last post, i can coast down it getting 80+ mpg, and when i go up it home each day i get between 18-24, usually around 22-23, not bad at all.
Old Jul 22, 2009 | 07:30 AM
JoeR's Avatar
Guys, there's a feature built into the ECM calibration called DFCO (Decelleration Fuel Cut Off). Under many conditions when off throttle, the fuel will be cut off to the injectors completely (= NO fuel).
If you just put into neutral, basically you're in an "idle" condition, where there is some (not much, though) fuel being injected.
IOW, it won't make a big difference, but you're more likely to save gas by just leaving it in gear.
Old Jul 22, 2009 | 09:58 AM
better?
i would think it would be better to have some fuel going into any engine while it is rotating....that is only my opinion....thanks for that info....due to that i may be coasting a little more in neutral , but i can't do it much because the terrain won't allow......also i don't understand how my mpg increases when put into neutral (according to the dash thingy) , unless it is causing mechanical "drag".
Old Jul 22, 2009 | 11:19 AM
GCarp's Avatar
Catdaddy,
Is that on an auto trans?
Just an FYI if an auto trans ... When putting it in neutral, you only need to bump the shifter - not squeeze the trigger. It shouldn't go past neutral this way. You can just bump it back and forth between drive and neutral this way.
Joe,
Is that on the Auto or Manual? I would think that something like that would be on the manual trans. With a manual trans there is a mechanical connection between the engine and trans. If you didn't have fuel going to the engine in an auto trans, wouldn't the engine just stop? (I may be wrong on this... there may be enough residual friction to keep the engine turning at speed?)
Old Jul 22, 2009 | 11:35 AM
[QUOTE=GCarp;399180]Catdaddy,
yep , auto...thanks for that....so , what about the 2 other gears ? will go down past D without the lever thingy?....is this info in my owners manual ?...i've heard of a few having issues with the auto shifter , so i've always tryed to be gentle but firm with mine....i really can't believe i put it in R , but i did....i get a little tired/stressed on my 275 mile a day route.
Old Jul 22, 2009 | 11:57 AM
twistrman's Avatar
mine is an auto as well, i never touch the button in, just a slight nudge between N and D. I've never tried to nudge past D since i've never really used the other 2 and would want to know what the I is for more before i did it.
in D i definitely think there is a mechanical drag. As soon as i switch over the mpg shoots up. Even if it didn't though, with Less resistance I can roll a lot farther. I have to watch the speed on mine since it is technically 25 or 35 (who knows...)
Old Jul 22, 2009 | 12:10 PM
DreamHHR's Avatar
I've had my scanguage show no fuel to engine (0 l/100k) in I gear on a long downhill last week. So fuel cutoff is for real; this was on my automatic. It's done it another time in D while I was coasting behind slow traffic.
The engine keeps turning and it's not any different than normal behavior on deceleration; in fact I couldn't tell if I was not seeing the scanguage reading.
What's the harm? The engine is still getting lubrication, and it's the transmission that is turning the engine, but other than a bit of an extra load on the transmission, I don't see what could go wrong.
Yves
