Gas Mileage
I Have The Auto Trans. I Am Terribly Disappointed With The Mileage. My Driving Is 75% Highway And 25% City. I Cant Even Get 'chevy's City Average' Of 24mpg. Usually, I Get Around 22 Mpg. I Dont Drive It 'hard' . I Am Conservative On Takeoffs. I Can Get It Up To About 24/25 Mpg On A 15 Mile Ride On The Highway. Once I Get Off The Highway, , It Drops The Average Down To Around 20/21mpg, After Driving For Less Than 5 Minutes Around Town. I Had A 2002 Grand Prix 3.8l 6cyl. Prior To The Hhr. It Was Loaded With Power And The Mileage Was Pretty Much The Same. I Didn't Mind Sacrificing A Little Power By Getting The Hhr, If I Was Going To Get Great Mileage. A 1 Or 2 Mile A Gallon Difference Just Doesn't Seem Worth It. How Are The Rest Of You Faring?
I average on the open road... 35 MPG..
Almost sounds like its running a little rich.
I wonder if you've got a borderline defective oxygen sensor that is flakey but not enough to illuminate a CEL (Check Engine Light)? Would be very unusual for a new vehicle, unless somehow some silicone based fluid or other substance harmful to O2 sensors got into your fuel. How is the engine running? Is it smooth and powerful? The main sensor the ECM relies on to set air/fuel mixture is the oxygen sensor. There are two plugged into the exhaust-- one in front of the catalytic converter and one behind it. The one in front is the one that the ECM relies on for feedback on the air/fuel mixture. The one behind the catalytic converter monitors emissions (sort of).
If the dealer can't find any other cause of the low mpg, ask them if they will, as a courtesy, change out the front (in front of the catalytic onverter) oxygen sensor.
On the other hand, it could be a flakey coolant temp sensor. If the coolant temp sensor isn't telling the ECM that the coolant is as hot as it really is, the ECM will continue to command a richer mixture thinking the engine is still warming up and not up to temp yet. On your DIC, does the coolant temp show 190 - 196 range most of the time after the car has been driven long enough? Coolant at full engine operating temperature should read in the 190 - 196 range. It will rise above this at stoplights etc, but come back down when cruising.
You have to make sure whoever is allowed to drive your ride is properly briefed and respects it. Sure, we can't be stingy old scrooges and selfishly refuse any other family members from the privilege of driving whatever prized vehicle is at hand, BUT they owe us some respect for the vehicle since they know we're gah-gah about it.
on my trips to L.A. from bullhead city, az and back I average 31.5 every time and there are some good hills too pull out of Needles on the I40. I went cruising the beaches in so cal last weekend and got 32.8 just cruising Beach bl, PCH and the local fwys. I am also looking for more mpg so will work on exhaust and intake mods.
