Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Mileage mods and strange results
Old Sep 29, 2008 | 08:22 PM
StormT's Avatar
Not to sure what the differance in RPM will be , but with my 2.4 5 speed i get better mpg at 50 mph than at 70 mph best is about 60 or so . i know there is a wind sheer factor/drag but if you are still in the torque band the lower RPM should help with the mpg ? yes or no? i have though that GM should have put a little less gear in the car to keep the rpm down .
Old Sep 29, 2008 | 08:30 PM
StormT's Avatar
PS car looks great no matter what the change in milage . did ya have spacers behind the wheels , might have find a set of these .
Old Sep 29, 2008 | 09:40 PM
Clevelandhhrss's Avatar
The car does look great :). Big wheels and a little lowering is almost always a plus.
Old Sep 29, 2008 | 10:28 PM
The Curly 1's Avatar
There is spacers
I have 7/32 (.218") Mr. Gasket spacers on all four wheels. I do not like the spacers and looking for better quality ones for the car. They do not cover all of the seating area on the wheels.
I do believe the combination of taller tires, lower RPM and the engine mods I am doing will increase mileage but I am not where I want it quite yet.
The car does look better in person, soon I will take some good pictures to post. With the wheels and lowering the car drives better and corners better than stock.
There is a Solstice Forum and sometimes they have those wheels on there. I bought mine from EBay.
Stock the car got its best mileage at about 60 MPH and I hope to move that up to about 70. Curly
Old Sep 30, 2008 | 04:02 AM
pappa_smurf's Avatar
Originally Posted by The Curly 1
I put a K &N filter on my HHR, not much change that I can tell on the mileage.
Then I put a set of Solstice wheels and tires on the Princess. She looks better and rides soo much better. The wheels are taller and I lowered the car so I was hoping for lower RPM and less wind resistance on the highway.
With the taller tires the was supposed to be a 11.64% speedometer error. It is the same (No change!) verified by my GPS!!!! How can this be? I am pretty sure the speedometer was right with the old shorter tires but I know it is right now with the taller tires? The tires went from 205 (23.25")-45-16 to 225 (25.97")-45-18.
At all speeds the RPM is the same? I did not have speedometer recalibrated or anything. With the taller tires RPM should be lower at the same speed and the speedometer should read about 10 MPH slow at 80 MPH.
Why is the RPM, Miles per hour and mileage the same?
RPM should be lower, MPH should be higher and mileage should be better due to.
I did notice for sure the car is much more smoother ride, more stable, does not blow around in the wind as much and there is less wind noise. Not sure how much of it is because of the lowering springs and how much is because of the wheels and tires but it is a whole new car and much nicer. The car can corner harder now too but that is not what I use it for. I may put the old tires back on to see if it is the tires or the lowering that improved the ride so much.
The car looks better now to.
So I am very pleased with the modifications but not exactly as I expected. Better ride and looks nicer but the RPM and mileage did not change?
I believe your original wheel tire set-up was your problem. Aren't the stock wheel/tires 195/65 R16? So, you had smaller than stock tires and that is where your MPH errors were occurring. Hence your mpg's didn't change as you expected when you went with the bigger 18" wheels. Just my 2 cents.
Old Sep 30, 2008 | 06:24 AM
There is a visable difference in size
There is a visable difference in tire size and should have a noticeable difference in speedometer reading. In fact there should be a 10% speedometer error now but there is not and I do not understand why.
So I suspect I may be getting better mileage than my DIC says because mileage, RPM and speed is reading the same yet the car is actually travelling further (maybe 10%) than it says. Yet my GPS did not show that much difference.
If that is true and it says I am getting 38 MPG on the highway and correct for the taller tires 10% you are looking at 41.8%. I have not been able to verify that with an independant source. Regardless I am pleased if there is a gain or not I like the way it looks and handles.
So the K & N filter may be helping some? Who knows?
Pappa Smurf, Do you have a picture of your car? The Aqua blue with the AA5 option sounds like it would look pretty nice.
Old Dec 13, 2008 | 02:17 PM
rforsland's Avatar
I see the error. the stock tires are 215/55-16 NOT 215/45-16. The diameter of the stock versus the 18's is minimal (25.31 vs 25.97), so the speedo is still within normal specs.
BTW, I found that H&R makes a 5mm (0.200 in) spacer in our bolt pattern. kind of pricey at $50 bucks a set, but they are billet and have the proper bore (65 mm).
My Solstice wheels should be arriving next week and I look forward to seeing them on my vehicle.
Old Dec 13, 2008 | 02:40 PM
TomsHHR's Avatar
I may be wrong, But the gain you are hoping to get with the tires might be lost with the wind drag at 70 MPG as compared to 60 MPG.
Just FYI, for better accuracy I would use the tire circumference not tire diameter.
Old Dec 13, 2008 | 10:16 PM
IgottaWoody's Avatar
Contrary to normal thinking,increasing tire size to lower rpm for milage purposes doesn't work on the newer vehicles.Heres how,,,the factory already has the car set to run the lowest rpm possible and maintain required epa and milage standards.Lowering the rpm further will only make the eng run harder thus use more gas.It lugs!I found this true on several cars Ive owned.If anything,raising the rpms slightly will probably gain better results as while the rpms are higher,the load on the eng is lower.Another thing to look at,these cars are highly controlled bythe OS,if the parameters don't match the system will try to correct it.Thats why when changing wheel/tire sizes its necessary to recal the speedo so the OS reads everything correctly.If the system does not correspond within the set parameters,you will not get the a correctly running moter.One change Ive made to another vehicle was a torque converter,went from an 1800 to a 2500 and it made all the difference in the world.(in reality it was 2200 due to the actual eng power) This enabled me to run 75 with AC and 2 bikes loaded in back and get 24 mpg in a 4800 lb(plus bikes) truck with a 5.7. Eng load dictatesn fuel usage,too low a rpm and you lug it.Looking at other 4 cyl motors that run at 2300 to 2800 rpm at speed,,the HHR runs low at 2000-2500.Gotta have torque to run at those rpms and hwy speeds and 4 cyls just don't have it.
Old Dec 13, 2008 | 11:10 PM
I actually agree with much of that
I agree with much of what you are saying about larger tire lugging the motor and possibly hurting mileage.
My hope is when I complete all of the performance mods it will have more than enough torque to pull it at a lower RPM with out hurting mileage.
I know the modern motors have to waste so much energy to overcome the intake and exhaust restrictions from the factory. My motor should be much more effecient than stock. (I hope!) In fact when I am done with most of the changes I plan on putting factory tires back on to do some testing and verify the results. Good, bad or indifferent I will post the results for everyone to see.
GDZHHR
2.4L Performance Tech
Oct 5, 2008 09:57 PM
turbofreak
Sep 11, 2008 08:38 PM
da_dad66
2.2L Performance Tech
Apr 12, 2008 08:15 PM
Mar 11, 2008 12:37 PM
