Mixing 87 and 93 Octane?
Ok, might be a stupid question, but does it hurt anything if I mix both regular 87 octane and premium 93 octane?
My truck runs on 93, so when I get gas for that I will typically take gas cans and fill up the HHR with those since I get a Kroger Fuel discount. Since I currently have 3/4 tank of 87 octane, will it hurt to top it off with 93?
So on another note, how is it that there are 3 different grades of gas at a station, if they only have one tank underground? How is it that one truck full of gas can be separate grades in the same truck, which all go down to the same tank, and come out of the same pump?
First, stations don't have one tank. Depending on the type of station they either have 2 tanks and blend the gas at the pump or they have 3 tanks and just stock 3 different octanes. Take a look sometime and you will see metal covers in the ground where the tanks are and they will be painted different colors to indicate what tank is which fuel.
As for the tanker truck, it doesn't have 1 tank in it. It has multiple tanks with multiple blends.
Look at one sometime and you can see multiple valves on the outside for them to drain from. Sometimes the driver will actually connect multiple hoses at the same time depending on how the truck is rigged.
bigjacksauto
2.0L Performance Tech
18
Jul 25, 2012 10:40 AM
