Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
5-speed from Cobalt XFE in HHR?
Old 03-31-2018, 10:54 PM
Heritage High Roof's Avatar
Would there be any benefit in swapping the standard 5-speed for the special 5-speed that came in the XFE Cobalt?
They had a 3.63 gear ratio instead of the HHR's stock 4.17 (or 3.95 in 2009-11 models).
My goal would be improved fuel economy.
The transmissions are available locally for less than $200.
Heritage High Roof is offline
Old 04-01-2018, 08:47 AM
Technical Moderator
Looks like it would bolt on to a 2.2L. From my reading it is 3.63 is 2009-. Evidently the ECM tuning changed to standard equipment in 2009 (VVT), so the only difference is the trans.
So, yes you would gain about 1 MPG city 3 MPG highway. I don't think you would be able to use 5th in the city.
donbrew is offline
Old 04-01-2018, 11:42 AM
Cat Man HHR's Avatar
Is the final gear (5th) the same for both?
First gear will be "slower" when taking off from a light.
Cat Man HHR is offline
Old 04-01-2018, 11:59 AM
Seems like a lot of trouble and cost for a possible small gain in mileage.
firemangeorge is offline
Old 04-01-2018, 12:07 PM
Technical Moderator
From what I read, the accel from 0-60 is ok. 50-70 in 5th is more than 13 sec. I'm guessing overdrive is different. If you want to pass on the highway you have to downshift.
donbrew is offline
Old 04-01-2018, 02:04 PM
Are those numbers for the cobalt? HHRs are what, 400 lbs heavier? Seems we were just talking about gear ratios.
I would also want to know what the ratio is in each gear, compared to stock, before I made that decision.
RJ_RS_SS_350 is offline
Old 04-01-2018, 06:14 PM
The final drive ratio is the only thing that changes. All versions have the same specific gear ratios and spacing.
I need to correct the original post as the F23 5-speed in the 2006-08 HHR actually has a gear ratio of: 4.17 and the 2009-11 was changed to 3.95.
The standard ratio in the Cobalt was 3.84 and the XFE had 3.63.
Old 01-11-2019, 06:06 AM
d0sitmatr's Avatar
depends on how long you plan on keeping the HHR
if you plan on keeping it long term, then it would pay for itself in a couple years. but outside of that I dont see it worth it time and $$.
but it is something to consider for someone like myself, who plans on keeping my HHR and passing it along to my son. Im pretty happy with the mpg I get now, or I should say Im surprised, as I see a solid 31-33 avg at highways speeds of 70mph with no traffic and no wind. if I get behind someone, Ive seen it go as high as 45mpg (scangauge verified) so a solid 2-3mpg gain on the highway would be worth it to me, especially since 90% of my driving is highway. :)
d0sitmatr is offline
slimsol
05-01-2010 09:41 AM
ecl
06-21-2009 01:47 PM
20vtguy
10-28-2007 10:18 PM
amberelyse
07-22-2006 05:57 PM
nabate
07-15-2006 07:41 AM
Quick Reply: 5-speed from Cobalt XFE in HHR?
