Saving a bit of gas
Saving a bit of gas
I just found out, if I turn on my air conditioner, coldest setting, fan on about the 2nd or 3rd notch, and put in in recirculating mode. I run it until there is cold air coming through for a couple of minutes. Then I shut it off, keeping it on recirc., it will blow cold air for the next half hour or so. Works best with the window opened a bit or the sunroof tilted up at the back. I can then run my air for only a couple of minutes each hour.
no in rec. mode it leaves the a/c on which is a/c max mode. if you put it on outside air you can turn the a/c off but on rec it will keep the a/c on.
