“Auto Light On” doesn’t work.
Old Apr 4, 2026 | 10:23 PM
hhr_operator's Avatar
The “Auto Light On” function of my HHR function is not working properly.
If I set it to “Turns on the headlamps, parking lamps, and taillamps. “, these lights illuminate. However they still remain ON when I lock my car.
If I set it to “Turns on the parking lamps and taillamps only. “, parking lamps and taillamps illuminate. However they still remain ON when I lock my car.
If I set it to “AUTO”, all lights turn off, even though it displays “Auto Light On” or “Auto Light Off”.
I have cleaned the light sensor on top of the instrument panel.
I also checked the following fuses and they are in good condition.
31 Daytime Running Lamps
63 Driver Side High-Beam
65 Driver Side Low-Beam
66 Passenger Side Low-Beam
67 Passenger Side High-Beam
Anybody else have this issue before? Please let me know how to fix it. Thank you.
Old Apr 5, 2026 | 07:28 AM
Welcome to the forum, it just might be your mutiswitch is malfunctioning. It happens.
Old Apr 5, 2026 | 08:14 AM
No mention of DRL? What year? Is this a new thing?
Old Apr 5, 2026 | 08:59 AM
Thank you. I will check the multiswitch. My HHR has a problem with battery drain. Do you think that might be related?
Old Apr 5, 2026 | 09:04 AM
The left headlamp doesn't work now and I will replace it. The year is 2011. The problem just happened recently. My HHR has a problem with battery drain. Do you think that might be related? Thanks.
Old Apr 5, 2026 | 04:10 PM
It’s very plausible the switch is the problem.
Old Apr 5, 2026 | 06:35 PM
Do the DRLs work or not? That is low beams/no tails during day light, when AUTO is selected.
Old Apr 5, 2026 | 07:38 PM
The DRLs don't work. Both low beam lights and tail lights don’t illuminate during daylight when AUTO is selected.
Old Apr 5, 2026 | 08:17 PM
Thanks. I am learning how to remove it.
Old Apr 5, 2026 | 10:27 PM
I would consider the light sensor or wiring to it.
