2006 HHR - Replaced liftgate switch & still not working
Old Oct 18, 2024 | 10:25 AM
88guy's Avatar
I have a 2006 HHR and about 5 years ago the liftgate switch went bad, I ordered one on Ebay, and that was the end of the problem. About 6 months ago it did the same thing and I ordered a switch. This time the new switch did nothing - i hook it up and nothing. I read some things about fuses and relays but they all appear to be fine. I think I read your not supposed to have anything in one spot in the fuse box (#11 as I recall a fuse or a relay or something) but I have done zero jerking around in the fuse box and the thing has worked for the last five years.
The thing has been parked for about two months but, as I recall, I heard a very faint clicking (just a couple of times) when I hooked up the new switch. But it wasn't enough to unlock the thing and that only happened a couple of times.
In other words, I know there is nothing in the fuse box that hasn't been there for years. Any ideas would be appreciated.
Old Oct 18, 2024 | 10:28 AM
greg8453's Avatar
Fuses and relays 'APPEAR' to be fine. How's that?
Old Oct 18, 2024 | 10:30 AM
88guy's Avatar
Well, I just pulled out fuses and none were burnt/broken. I am a nitwit with this kind of thing. Maybe a relay is bad or something.
Old Oct 18, 2024 | 11:48 AM
Try switching similar relays with relay #18 in the under hood fuse box .
https://fuse-box.info/chevrolet/chev...uses-and-relay
Also with a 7 mm socket tighten the four bolts in the fuse box , real tight!
Those four bolts ^^^^^
Old Nov 7, 2024 | 05:37 PM
88guy's Avatar
I'm an idiot. I replaced the soft touch pad "thing" first, then I spent 32 bucks on the latch mechanism.....then I finally replaced the relay (when nothing had yet worked) and it was the relay - and I had spent 30 bucks on a 2006 fuse box about a month ago and had one sitting in the garage the entire time......DOH.
Old Nov 8, 2024 | 07:12 AM
It’s fixed! And you have spare parts ! 🥳
Old Nov 8, 2024 | 08:16 AM
PulpFriction's Avatar
Some shops get paid for that kind of bungling. You got it for free. Call it a win.
Old Nov 8, 2024 | 09:36 AM
Lonwane's Avatar
AND, that is something we ALL have done.
bigdog9586
Jun 18, 2022 07:54 AM
Radco
Maintenance and Upkeep
42
Mar 3, 2022 02:53 PM
rock10
Jun 9, 2019 06:50 PM
wotowoto
Feb 4, 2012 08:45 PM
bigdog9586
May 24, 2008 10:27 PM
