2007 HHR 2.4L died
Old Nov 14, 2023 | 07:26 AM
A stuck open thermostat won’t allow the coolant to heat up. But while you have the head off, replace the timing chain and water pump!
Old Nov 14, 2023 | 08:43 AM
Agreed, the stuck open thermostat did not cause the overheating.
Maybe a bad fan, or loss of coolant because of a blown head gasket. So the question is did the overheating cause the head gasket to leak (warped or cracked head or block)? Or did the damaged head gasket (warped or cracked head or block) cause the coolant loss that led to the overheating?
Old Nov 14, 2023 | 11:36 AM
Ed ke6bnl's Avatar
It was removed stuck closed
Old Nov 14, 2023 | 12:45 PM
greg8453's Avatar
A thermostat that doesn't open will cause an overheat.
hurst2001
May 17, 2020 01:55 PM
Mark Honomichl III
Jan 6, 2020 05:01 PM
Mudboy_86
2.4L Performance Tech
Sep 18, 2018 10:59 AM
Danman03
May 12, 2016 04:08 PM
