2008 chevy cobalt sunroof leak
My current leak is from the left front (driver’s side) sunroof drain. I could not get a weed whacker line through the drain tube and when I poured water down the drain it created a puddle on the floorboard.
When I removed the sill, kick panel and peeled back the carpet, I found the firewall was wet. I searched the forum and found a pic of the passenger side drain tube, but the driver’s side is different. Where is the drain outlet? It is not in the frame when I open the door. Has anyone had experience with the driver’s side front drain? |
Maybe you should check at a Cobalt forum. They are not the same as HHR.
I don't own a Cobalt , so no I don't know we're the drains are in yours.
The Cobalt site should How to Clean Sunroof Drains? | Chevy Cobalt Forum - Cobalt SS | Cruze | Saturn ION | Pontiac G5 Forum |
