Abs hub on non Abs HHR??
Does anyone know if you can use a Abs hub on a non abs hhr? The axel shaft is the same. Price is lot cheaper for abs is why I am asking. Thanks
You can, and why the ABS hubs are cheaper still mystifies me. Just make sure you compare the parts before installing the hub.
Thanks for the quick response. I will order the abs set from Ebay.
More cars have ABS then not. The old S & D game. Sell more
Yes, you can. It's what I did for the HHR and a Ranger rotor/hub. IIRC, the plug for the sensor can just be pushed out of the way.
