Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   AC Compressor Time (https://www.chevyhhr.net/forums/general-hhr-4/ac-compressor-time-60281/)
RJ_RS_SS_350 May 15, 2018 06:22 PM
Yes, they need burping. https://www.chevyhhr.net/forums/hhr-...-system-59224/
SwaintaN May 15, 2018 11:12 PM
I'll try to burp it this weekend. Thanks.
SwaintaN May 18, 2018 07:43 PM
MIND BLOWN:
So AC tech in Findlay (next town) charged me 20 (ended up being 50.xx) to do a basic test so he could(nt) find out what was wrong, so we could fix it at home.. What i got was a damn paper off with notes.
"AC Clutch Fully Engages
HIGH/LOW Pressure is adequate.
A/C Relay, swapped, stock #
Interior A/C on/off switch positive for power and function.
No Leaks detected."
That along with cost is what i got back. Like really WTF. Then recommended a tire shop, i was like "yea so they can charge me to tell me my tires are tires".
donbrew May 18, 2018 09:09 PM
Did anyone check the diode? The pressure switch?
SwaintaN May 18, 2018 10:19 PM
Im gonna have to contact them to see what was all checked (the list is literally a sticky note on the bill), how do you check those, if i can check em I will.
donbrew May 18, 2018 10:21 PM
The diode is in the fuse box, check it for continuity in one direction only. Position #9.
Jump the pressure switch, if that fies it get a new one.
SwaintaN May 20, 2018 06:00 PM
https://cimg6.ibsrv.net/gimg/www.che...9dcc2551e5.jpg
im assuming this is the proper pressure switch. diode checked out good.
when you say check it, just making sure doing it right, jump the wiring not the switch that is screwed in.
donbrew May 21, 2018 09:43 AM
Actually, I was wrong about the switch. It is actually a sensor, the ECM does the switching.
A new one runs $10 (ebay) to $32 (AutoZone). EZ screw in job, there is a Schrader valve in the hole.
SwaintaN May 21, 2018 10:09 AM
Ok. Still number 1 in the picture? I saw it just screwed off and screwed back on. Looks covered in oil from old motor.
firemangeorge May 21, 2018 11:36 AM
Yes. The silver thing inside the red circle. Looking from the middle bottom upwards.
https://cimg6.ibsrv.net/gimg/www.che...5453857ec7.jpg
