Ac not as cold
I have a 2008 hhr with almost 200 000 miles on it, the ac was blowing cold now it started to blow a lot less cold after I got gas and turned it on, I know that the thermostats bad I just haven't replaced it yet, I know sometimes that shuts down the ac but when that happens the temperature guage doesn't work, the temperature guage still works but not the ac, I'm pretty sure I can hear the compressor kick on
Replace the thermostat AC Delco 131-158 180 degree , only! and the Dexcool only lasts 5 years so drain and fill with 50/50 mix
Originally Posted by Dave1972
(Post 955348)
I got gas ?= put freon into system or gasoline in tank? Do you have an engine running hot trouble? A cooling system flush and thermostat service will help that. Seems you are combining the A/C not working symptom with engine cooling. Priority would be the engine correctly at the optimal operating temperature. |
Originally Posted by WoodysMobile
(Post 955353)
Need more information and clarity;
(Post 955353)
Don't look at the gauge, look at the digital temp. If you have as P0128 the AC is disabled.
X2 ^^^^^^^, that code? Is it P0128? Change out the thermostat!
....................X3 change the 'stat & service the cooling system too if possible (flush and refill w new antifreeze-H2O mix)
clear the code(s) and let's see where it's at after that! |
Not just coolant….Dexcool and potable water 50/50 mix!
A stuck open t-stat does not cause overheating it causes underheating.
| All times are GMT -5. The time now is 02:06 AM. |
