Analog Temp. Gauge vs DIC Temp. Readout
Old Aug 25, 2007 | 07:50 AM
kornellred's Avatar
Hi Everyone -
My 2007 HHR LS achieves normal operating temperature within a minute or two of driving. The analog temperature gauge gets to the mark just below the longer halfway mark. And stays there.
At long traffic lights and in stop-and-go traffic conditions, the coolant temperature can vary as much as 15 degrees (about 190 to 205) according to the DIC. The analog gauge needle, however, shows no sign of movement.
Perhaps a mere 15 degree change will not cause the temperature gauge to respond, but I feel that the gauge needle span is wide enough so that a 15 degree change should provoke at least some movement.
Anybody else experiencing this? Engine temperature is critical information, to say the least!
Willie R.
Old Aug 25, 2007 | 08:12 AM
Dan's HHR's Avatar
same here, don't worry about that
Old Aug 25, 2007 | 09:22 AM
mizzouHHR's Avatar
I've experienced the same thing and wondered about it also. a couple of weeks ago my DIC temp was actually 218, and the needle was still at that same mark. I guess as long as it isn't overheating I'm not going to worry about it.
Old Aug 25, 2007 | 12:07 PM
nfboy's Avatar
From an engine operating temp POV, 15 degrees is nothing.
Old Aug 26, 2007 | 06:39 AM
TomsHHR's Avatar
placement of the sensor could be the factor on your temp readings, I would guess.
dbranga
Dec 4, 2016 01:01 AM
Snoopy
Dec 5, 2013 04:15 PM
Bser2000
Aug 1, 2009 09:19 AM
Norsican
Aug 12, 2008 07:05 PM
Black Raven 2008
Jul 30, 2008 09:33 PM
