Annoying vent noise
Annoying vent noise
There is a noise coming from the right side that only happens when I got the vents going, doesn't matter if its a/c or the heater. It really quiet and it just sounds like really quick clicks one next to another. Sounds almost like someone is reeling in a fishing pole nonstop when I drive. I paged my salesman and when I get more information I'll post it.
The leaf would gain access in the underhood area. Also, I believe there is a cab filter you might be able to access under the dash - pull it out and inspect, you might find the problem there.
Hope it helps,
Hope it helps,
I checked it out real good and opened the glove box and pushed the tabs and really got up under there and i saw what im guessin is the ac unit, it said delphi on it(yea im a real car buff huh) and it sounds like the noise is comin from it more than the vents really.
I have seen that type of problem in several cars. The fan is press-fit onto the shaft of the fan motor. If the plastic fan is not within the right tolerances and the hole for the shaft is a little large, the fan will float down the shaft. Thus the fan then starts rubbing on the first thing it comes into contact with. Then WA-LA - you have an instant annoying sound!
I don't think something else would have caused it. It was probably just a defective part. The blower fan went on my Grand Am but the car was 7 years old at that point and not a new vehicle like yours. I'll be keeping an eye on it now that I know someone else has had a problem.
