Arm Rest?
Old Mar 21, 2008 | 06:57 PM
jcgc50's Avatar
Arm Rest?
I have seen prior posts noting that the armrests slant too low down. I thought that was fixed for 08 but apparently not. At least not on our car. The passengers seems ok but the drivers tilts down.
What has anyone done to correct this?
Jim C
Old Mar 21, 2008 | 07:20 PM
DreamHHR's Avatar
Remove armrest. Drill a small hole in the channel and put a metal screw in it (essentially a new stop). Figure out how much correction you want beforehand, not much was required on mine, like only 1/8" to 3/16".
Yves
Old Mar 21, 2008 | 09:45 PM
dr_fosg8's Avatar
Dream, do you have any pics on the removal of the armrest? I would like to change the level of my armrests.
Old Mar 21, 2008 | 10:13 PM
oneton's Avatar
Take out the plastic plug on the outside of the armrest,not sure of the size of bolt 17 or 18 mm. remove bolt take off armrest. You will see a cruved slot, find where you want it to be drill hole put in screw reinstall armrest
Old Mar 21, 2008 | 11:36 PM
Big Kahuna's Avatar
Mine was under warranty...
Made an appointment with the dealership and they replaced both of mine with new armrests at no charge.
Old Mar 22, 2008 | 07:45 AM
GCarp's Avatar
I didn't have to drill anything. I just put a sheet metal screw in the end of the slot (thread it into the slot) and that was enough to do it.
Old Mar 22, 2008 | 12:28 PM
Snoopy's Avatar
Over a year ago, I did the modification that several have suggested here. But on a recent trip to my dealer, I had them REPLACE the armrest per the TSB that addresses this problem.
You might want to refrence TSB #07-08-50-007
Old Mar 22, 2008 | 02:25 PM
Black Rose's Avatar
I had the TSB applied last year.
Better than it was from the factory, but still didn't totally resolve the problem.
Old Mar 22, 2008 | 07:32 PM
prod's Avatar
I havent noticed a problem with mine, but I dont use them much. Was this problem addressed on 07-08 vehicles?
Old Mar 22, 2008 | 07:58 PM
courthousedeb's Avatar
Here's the 7 page thread about the armrest issues. Apparently not fixed on subsequent models either.
https://www.chevyhhr.net/forums/problems-service-repairs-42/new-service-bulletin-uncomfortable-armrests-7435/
IndianaJ.J.
Apr 5, 2011 08:54 AM
dpoll995
Jun 20, 2010 09:54 PM
THE BATMAN
Apr 7, 2009 05:53 PM
dpoll995
May 16, 2008 12:28 PM
