Battery ground
Old Oct 23, 2018 | 07:32 PM
Isaiah Mahood's Avatar
Battery ground
where is a better place to put the ground of the battery?
Old Oct 23, 2018 | 07:36 PM
What is wrong with where it is?
Old Oct 23, 2018 | 10:56 PM
better ground
im dash lights and air bag light and radio lights go dim on their own and they get bright again. my altnatior is putting out 14.7 volts.
Old Oct 24, 2018 | 01:18 AM
The current ground connection is perfectly fine, as long as the contact is clean. Why do you think it is due to a bad ground?
Have you tried adjusting the brightness of the lights via the switch on the dash?
Old Oct 24, 2018 | 01:21 AM
yes i have
i have played with the switch many times. i think im getting a bad ground some where
Old Oct 24, 2018 | 07:31 AM
The dimmer switch could be going bad, but, if you don't think so, I would then suspect a common ground point that is shared by those affected lights.
Maybe this ground location ?
Old Nov 2, 2018 | 05:39 PM
Blue_SS's Avatar
Clean it, improve it. Don't move it. ONLY a humongous ignoramus would consider it. Please do not do that...
I might just dump 100 bags of oak leaves on you, and light them on fire... You can survive, but like this, it's dumb to even try it...
For no reason..
Old Nov 2, 2018 | 05:50 PM
My oaks won't be finishing until Feb., but I got lots of Hickory and Gum and the first few Oak..
longhornss
Feb 27, 2009 01:15 PM
jshandra
Aug 11, 2006 08:37 AM
fenris222
Jul 24, 2006 09:30 AM
fishbreath
Mar 29, 2006 05:14 PM
