Bcm, tcm, pcm, ecm????????????
What does our cars have?? I thought we had a BCM and PCM, but everytime I use the term BCM with a person they keep correcting me and saying I must mean TCM.
BCM=body control module, ???????????? what does it do? TCM=transmission control module, ???????????? WFT?? :roll: I am very confised and someone is using it against me. Can someone PLEASE help me out? :confused: |
We have a:
BCM = Body Control Module. ECM = Engine Control Module. TCM = Transmission Control Module. PCM = Powertrain Control Module (Used prior to our vehicles which was basically an ECM and a TCM together). EBCM = Electronic Brake Control Module (For ABS equipped vehicles). And there are others that aren't important. |
Thanks!
so which one is part# 24234503
Originally Posted by GDZHHR
(Post 420844)
Yeah I know, I just found the invoice. Plus I wanted to know the other stuff too.
Originally Posted by ChevyMgr
(Post 420828)
... OK, I'm tired of typing, and the list is getting silly |
(Post 420844)
If it is mounted where the ECM is it's a TCM if it's a BCM it's the interior electrical center (fuse box). Mike give me your last 8 of the VIN and I will find out what part number BCM and TCM you should have. |
(Post 420873)
I think a TCM, by an internet search. I wont' know until Monday because I have the weekend off. Yay!!
If it is mounted where the ECM is it's a TCM if it's a BCM it's the interior electrical center (fuse box). Mike give me your last 8 of the VIN and I will find out what part number BCM and TCM you should have. So my TCM got fried, not my BCM. :roll: |
#24234503 is a TCM.
| All times are GMT -5. The time now is 05:09 AM. |
