Bulb type
Old Feb 22, 2026 | 05:21 PM
kmdakota1's Avatar
Bulb type
Looking for the little bulb that goes in the gear selector light up display. I had read it was a #37 so that's what i bought. It looked just like the one I took out but it's not. It is a tiny bit wider and will not fit into the socket. Anyone got an exact part number and brand. The only other one at autozone I believe was #38. Don't quote me on that number but it was a similar looking type bulb which I also doubt is the right size. Is this going to be a dealer only part?
Old Feb 22, 2026 | 07:22 PM
I’ve always used the #37 mini bulb, check your bulb socket for any signs of melting
Old Feb 22, 2026 | 09:10 PM
All of the bulbs are listed in the Owner Manual (link in my sig).
Old Feb 23, 2026 | 11:46 PM
kmdakota1's Avatar
The owners manual does not refer to this bulb
The socket is in perfect shape
#37 will not fit into socket. The bulb that is in there is not as wide as the 37 but if you put them side by side you wouldn't know. It's not until you try to put it in that it becomes apparent.
Google searches only point to the 37. Nothing else that even closely resembles the bulb comes up.
I don't need to see the shifter I guess anyways, lol!
Old Feb 24, 2026 | 03:25 PM
kmdakota1's Avatar
Found the bulb. #15879670 gm part. Autozone has them in their warehouse. Will have tomorrow.
Old Feb 24, 2026 | 04:01 PM
According to our sources, the 37 bulb is the one! See post 19 and 20
https://www.chevyhhr.net/forums/main...s-38073/page2/
Old Feb 24, 2026 | 04:39 PM
kmdakota1's Avatar
hmmm, interesting! #37 definitely does not fit. I'm curious if the #15879670 gm bulb is the same as the Sylvania #37. Will post after I get the bulb.
https://www.gmpartsstore.com/oem-par...caAl73EALw_wcB
Old Feb 24, 2026 | 07:00 PM
I’ve installed the 37 in my 2007 and 2011 years
Old Feb 25, 2026 | 12:20 PM
kmdakota1's Avatar
First pic is the #37 bulb. Second pic is the GM bulb #15879670 that I received today and is identical to the one I took out. The GM bulb fits perfectly and is definitely not the same as the #37.
This is on a 2009 LT. Hopefully maybe this post will help others having the same issue.
Maybe the socket was replaced or something prior to us owning the car, don't know.
Old Feb 25, 2026 | 12:22 PM
Hopefully! Thanks for posting
