Car will not start after battery removal.
thanks for the reply but now I'm getting comm errors when I insert a new scan tool with live data to check O2 sensor. I have tried several code readers but they all cause comm errors. I'm now trying to reset the ECU by disconnecting the battery. Will report later.
it was running at one point but I removed the ecu connector
The last time I disconnected and reconnected my ECM, the "handle" on the connector would not go down all the way. I discovered that the gear mechanism had slipped a tooth. So the connectors were fully together, but I couldn't lock it in place.
Perhaps your connector has slipped a tooth in the other direction, so your handle is locked down, but the connection is not complete.
