changing air filter
Old Apr 14, 2006 | 12:17 PM
chevyman's Avatar
Exclamation changing air filter
ho do i need help!
has any one done this yet.i have look it over but not sure how to take it off
man i wish i had 'nt skiped auto shop. need help do'nt want to take it back to dealer.
Old Apr 14, 2006 | 12:23 PM
captain howdy's Avatar
Don't you have an owners manual? It tells you how to in it.
Old Apr 14, 2006 | 01:11 PM
SoCalHHR's Avatar
I don't have pictures, however it is easily removed.
From the Owner's Manual:
To inspect or replace the filter, do the following:
1. Disconnect the MAF sensor, PCV hose, and both ducts.
2. Pull the entire system from the top of the engine.
3. Flip the system over and place it on a soft, non-abrasive surface.
4. Remove the screws that hold the housing and cover together and lift off the housing.
5. Inspect or replace the engine air cleaner/filter.
6. Reverse the steps to reinstall the system. Be sure to reinstall the housing tightly.
Hope it helps,
Old Apr 14, 2006 | 01:12 PM
chevyman's Avatar
yes but it's real clear to me. there is a brace with a star bolt on the the left hand side of the t.ruck do you take this off
06chevyHHR
Maintenance and Upkeep
Apr 17, 2015 05:07 PM
bigallis1
62
Dec 4, 2010 11:31 PM
mr.2lt
Oct 9, 2010 11:23 PM
wickedj
Jul 21, 2008 08:13 AM
Offy
Mar 13, 2008 07:41 AM
