Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Changing trans fluid (https://www.chevyhhr.net/forums/general-hhr-4/changing-trans-fluid-33030/)
SteveMaine Dec 20, 2010 05:45 AM
I have a 2006 HHr and would like to change trans fluid as I have over 100,000 on it. Can't even find place to check level. Thanks for any help.
solman98 Dec 20, 2010 06:31 AM
There is no dipstick. Mines a stick so I can't say for sure, but it would either have a pan to drop or a drain plug. There is a fill hole also (again, not sure of the location).
whopper Dec 20, 2010 10:59 AM
The search engine at the top of the page is your friend. :)
IE: https://www.chevyhhr.net/forums/show...s+fluid&page=3
SteveMaine Dec 22, 2013 02:20 PM
2006 HHR transmission filler plug
Changing auto trans fluid in my 2006 HHR. I can see the filler plug but how do you get your hand down there to unscrew it. ??? Thanks for any help.
Of coarse I drained fluid before finding filler plug.
whopper Dec 22, 2013 03:03 PM
A quick search with the SEARCH TOOL at the top of the page looking for "transmission fluid change", gave a nice link to https://www.chevyhhr.net/forums/maintenance-upkeep-50/transmission-fluid-change-easy-42736/ which describes how to get to the filler cap. :)
donbrew Dec 22, 2013 07:03 PM
You just worm your arm through the wires, It is about 2 inches high and easy to grip.
Use a long neck flexible funnel to refill.
