cheap fix/cup holder
This is a good fix. Go to Wal-M / K mart...
buy the Roadmaster 16oz travel mug / take the mug to where you buy O-rings for water filters/ get some velcro/ pull the rubber cup holder liner out of the base/ tape the velcro to the base & the other velcro to the mug /put the base back/put the O-rings (I used two for each cup) on the cup from the bottom just enough that they are almost tight/ now let the O-rings center the cup as you push it into place. Done ! This helps you with the reach. It will take a 12oz soda/pop can your your fountain drinks (no big gulp) & for you speed-heads yes your STARBUCKS. try it out. later rNr // mike |
DO you have a pic? That might help me figure out what you did exactly.....:confused:
Better Patent that Idea :nuts: :nuts: :nuts:
Originally Posted by solman98
(Post 137733)
(Post 137736)
Thanks
Goose |
Cant visualize that one!:roll:
(Post 137733)
later rNr // mike |
It's simple:
Buy a big travel mug. Put O-rings around the bottom of the mug. Put Velcro on the base of the mug and bottom of cupholder. Place the mug in the cupholder. The Velcro and the O-rings will hold it in place so you can use it as a raised cupholder. Only problem is that it won't hold my insulated coffee mug with the handle. |
Is this gonna be called the "rockNroad cup holder" mod ?
Originally Posted by hhrcrafty
(Post 137809)
It's simple:
Buy a big travel mug. Put O-rings around the bottom of the mug. Put Velcro on the base of the mug and bottom of cupholder. Place the mug in the cupholder. The Velcro and the O-rings will hold it in place so you can use it as a raised cupholder. Only problem is that it won't hold my insulated coffee mug with the handle. LATER rNr// mike |
