check engine light stays on after repair
New thermostat (oem) ACDelco 131-158 installed
after a while...... coolant guage flattens - digital coolant guage goes blank, ac goes off I erase code, p0128, guauge comes back on, ac starts After a while Check Engine Light back on again coolant guage flattens - digital coolant guage goes blank, ac goes off clear code, guage back on, ac on |
Then the temp sensor is bad.
air in system?
X2^^^^^, you need to burp the system first, then if still getting the code , change the coolant sensor.
