Cleaning drums with brush
Old Apr 17, 2008 | 04:21 PM
Goose's Avatar
Gonna be putting my polished rims on and thought I'd try to clean up some of the rust on the drums....what kind of brush should I use?
I picked up one with brass bristles at Pep Boys but don't want to hack stuff up either...ok to use?
Goose
Old Apr 17, 2008 | 04:39 PM
an08HHR's Avatar
A Steel wire brush won't hurt the rear drums, sand blast them if they are real bad, then paint them with a hi temp paint.
Old Apr 17, 2008 | 04:44 PM
Goose's Avatar
Brass too tough?
Goose
Old Apr 17, 2008 | 04:48 PM
an08HHR's Avatar
Brass is soft, I would use a brass brush to clean crud off calibers and alum parts.
Old Apr 17, 2008 | 05:46 PM
Goose's Avatar
Moot point as I can't get the &^%$# lugnuts off with weak azz OEM wrench.....what are you guys using?...I guess I'm not strong enough to bust 100 ft pounds lol
What are you using to bust these puppies off?
Goose
Old Apr 17, 2008 | 06:04 PM
an08HHR's Avatar
breaker bar and deep socket. Drop a flea on the end of the handle and nuts come right off.
Old Apr 17, 2008 | 06:10 PM
HHR_ROX_CALI's Avatar
I like the 4-way aftermarket lug wrenches. Built-in handles!
Old Apr 17, 2008 | 06:26 PM
an08HHR's Avatar
just going to add a note and say anyone that will be changing tires on their car, it will be well worth buying a 4-way as HHR_ROX_CALI said and or a 1/2 drive breaker bar about 14-15 inches long and get 6 point deep sockets the size you need. It will be one of the best investment you can make. I've been using my breaker bar for 45 yrs and don't think I've ever used a oem wrench on lug nuts.
Old Apr 17, 2008 | 06:30 PM
saltyfishguy's Avatar
air impact wrench
Old Apr 17, 2008 | 07:17 PM
Goose's Avatar
So 4 way my best (and most inexpensive) bet? Be able to muscle the lugs off with that?
Goose
