Are code P0010, Service ESC and TRaction related?
Old Oct 12, 2019 | 02:44 PM
BigT's Avatar
Check engine light comes on for a few days then goes off, then comes back on a few day later with also Service ESC and Service Traction. Then these go off and come back on some other day. Right now all I have is the Check engine light. This has been going on for about 2 months. I changed oil the first time the light came on and that kept it of for about 3 weeks. I checked for code and it is P0010. I know what that is and how to fix it. What I need to know is why am I also getting the service ESC and Traction. Are these related to the P0010 also?
Old Oct 12, 2019 | 03:49 PM
Yes. What are you going to replace? NOT the sensor.
Old Oct 12, 2019 | 04:04 PM
BigT's Avatar
I believe it's the solenoids. Exhaust specifically but I will get both of them. I had taken them out and cleaned them when I did the oil change so I have done that before.
So, you say the P0010 (solenoids) is also the reason I am getting the message about the ESC and Traction?
Old Oct 12, 2019 | 04:05 PM
These.
I've had them in my parts bin for a month. The P0010 I've had a lot longer. Need to get off my arse and get them put in.
Mines never had the Service ESC or any other lights, just the CEL. Maybe the programming is a little different with the SS and doesn't trigger the other warnings ? Not sure.
Old Oct 12, 2019 | 04:29 PM
At least you won’t get your hands dirty on your SS , maybe a little oil.
Old Oct 12, 2019 | 04:40 PM
They are actually called VVT valves,
Eric Overmiller
Mar 22, 2018 10:07 PM
flstss
Nov 16, 2017 08:51 PM
pipilo
Sep 2, 2017 09:43 AM
Lowe GJoel
Jun 7, 2016 12:10 PM
Alexwsilver2010
Aug 9, 2014 10:41 AM
