Originally Posted by Ryan Luttio
(Post 842515)
Is it possible for the temp read out to be working, but the thermostat still be bad? My 06 2.2 threw this code, and besides running about 10º cooler then normal, all the readouts seem fine.
Have a lot of miles on the car? Change the thermostat and more than likely change the anti-freeze. Get the Delco T-Stat only. This p/n may have been updated. https://www.gmpartsdirect.com/oem-pa...bC1sNC1nYXM%3D |
Originally Posted by Cat Man HHR
(Post 842517)
From what I've read that deals with how fast the water temp comes up to keep the ECM happy when starting cold. If that parameter isn't met you will get that code.
Have a lot of miles on the car? Change the thermostat and more than likely change the anti-freeze. |
Was a Delco part installed when the coolant was changed? Or did someone just do drain/refill?
It was just a drain/refill. I had it done same time that I had a bunch of little maintenance things done before traveling cross country. Thinking back I should've had them do the thermostat just as a preventative, but it didn't cross my mind.
Then do it and see what happens.
Bet you the code goes away. |
X 2!!
My money is on the T-Stat and bleeding the air out if the system.
166F is a lot more than 10 degrees cooler! It should be above 180F.
It could be the temp sensor, but you can visually inspect the t-stat before spending the money. |
Originally Posted by donbrew
(Post 842527)
(Post 842528)
166K is the miles on the vehicle.
