Control arm bushings
I gave you the part numbers the rear bushings are the same for all years of HHR, they will fit!
Many parts aren't listed for the 2011's cause they're just lazy and don't care to confirm fitment!
Updated the parts list:
Lower Control Arm Rebuild Parts
- Duralast Rear Bushing (autozone) P/N - FB782 (2.37" or 60.2mm outer diameter)
- MOOG "problem solver" Rear Bushing - K200792
- MOOG Ball Joint - K80567 (require drilling out old one and bolting this in - FE1/3 ONLY - does NOT fit FE5)
- MOOG front LCA bushings - K200361
Apparently we need to update again
Moog has released bushings with the aluminum LCA
K201285
But the K200792 do fit and work fine and are now listed for the HHR,
Just not plated
http://www.moogparts.com/pdf/problem...failure_EN.pdf
K201285
Just not plated
Could it make sense to replace the complete LCA? As seen here:
Federal-Mogul Motorparts
Would it include all the parts mentioned above by whopper?:
Is the part on the left hand side of the picture the rear bushing? If yes, it looks a bit different than K200792 to me.
Just buy the complete MOOG unit and install it that way, that is what I did. Got them off AMAZON.
Just be sure to bring an impact gun, cheater bar, and patience; that rear bolt can be a pain coming out and going in. For me, it was the going in part.
Goose
May 30, 2007 07:11 PM
