Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Coolant Temperature (https://www.chevyhhr.net/forums/general-hhr-4/coolant-temperature-27035/)
andoll83 Dec 6, 2009 08:05 PM
Coolant Temperature
Hello All---
Okay, this may be just plain ignorance on my part, so please don't laugh, but here goes:
A little background (perhaps unrelated):
I had my thermostat replaced in early October, due to the "---" reading on the DIC.
Yesterday my battery died, so I had it jumped.
I then had my tires and rims swapped out for my studded snows on steelies.
Here's what happens:
Later that night, I started my car (tried to), but the engine just wouldn't fire until I pumped the gas a few times. This happened a couple of times when I tried starting it, then it started fine without pumping..... later on, it happened again.
The remote start sporadically worked as well (replaced the batteries and both remotes seem to not work here and there, or I have to push the buttons really hard for a few seconds).
I also noticed that the coolant temperature on the DIC read "---," which was annoying because I just had the thermostat replaced. But after I started it the next day, the coolant was reading 32 degrees Fahrenheit when I just did a test-start (perhaps because it's starting to get cold here in central New York?).
Started it tonight and the coolant temp read 68 degrees to start, and slowly rose between 180 and 201 as I drove it (higher temperature was only when the car was idling)....
Is it normal for the temperature to fluctuate like that?
The needle on the dash, though, didn't quite reach the midpoint of the scale though (is it supposed to?). Here are some pics of the needle:
https://www.chevyhhr.net/gallery/fil...1206092031.jpg
https://www.chevyhhr.net/gallery/fil...1206092023.jpg
https://www.chevyhhr.net/gallery/fil...1206092022.jpg
I really appreciate all of the help on this forum, thanks guys!
Andy
jx3 Dec 6, 2009 08:32 PM
Coolant temp on Dory usually floats between 196 to 205.
Sounds as if yours is reading just fine.
andoll83 Dec 6, 2009 08:37 PM
ok well that sounds like some good news, where does the needle usually sit on the gauge when she's warmed up?
jx3 Dec 6, 2009 08:44 PM
A bit lower than the half mark.
andoll83 Dec 6, 2009 08:48 PM
thank you! wonder if anyone else will chime in about the engine/remote start and such
harleysshhr Dec 6, 2009 09:38 PM
check your coolant level and see it it is a little low. That could result in sporadic readings.
txbass06 Dec 6, 2009 10:23 PM
Mine normally reads between 196 and 201 and the needle is usually a bit closer to the half mark than yours is in the 3rd pic
ecl Dec 6, 2009 10:54 PM
Whats the highest temp seen or safe? Ive seen mine reach 220 a few times.
txbass06 Dec 6, 2009 11:07 PM
202 is the highest temp I've seen mine reach
oneton Dec 7, 2009 07:24 AM
I have seen 220 here in FL. in stop & go in summer.
