Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Counter balance sprocket tool (https://www.chevyhhr.net/forums/general-hhr-4/counter-balance-sprocket-tool-64313/)
Gearhead1 May 9, 2021 11:02 PM
....seems lot of folks are having trouble getting those bolts loose like i was...
I may need to make a tool...better version of what i did using the okd chain to lock it from rotating....
....one of them “round to it’s”
Oldblue May 10, 2021 05:07 AM
I just use the 5/16 drift to place in the hole and engage the teeth of the sprocket, I suppose a chain vide grip might work also
https://cimg2.ibsrv.net/gimg/www.che...736c5fe3c.jpeg
Gearhead1 May 10, 2021 05:58 AM
I was going to do that too but car body was in the way
Oldblue May 10, 2021 06:06 AM
I just lowered the engine a bit on the jack. You have to to get that water pump bolt out, so that’s when I have the room to get in there.
Gearhead1 May 10, 2021 06:10 AM
I lowered mine too....until it was against the sub frame....punch was to long...about 4-5”....so i used the old chain and vise grips to hold it. OCD...so the new gears had to go on...lol
donbrew May 10, 2021 08:56 AM
GM says don't remove the sprockets, remove the shafts. Shouldn't need replacing.
