Difference with the 2.2 and 2.4 engine
What are the actual differences between the 2.2 and 2.4, is it possible that GM uses the same engine, but for the 2.4 the intake and trottle is bigger, but what else can there be.
thanks for a better understanding |
what do you thing 2.2 and 2.4 stand for? engine size in Liters. For old timers that are use to cubic inch, it is roughly 134 cu in vs 146 cu in. In 06 models the 2.4 had variable valve timing and the 2.2 did not. Size does make a difference.
2mm difference in bore size(88 to 86mm). diff cams ,larger TB and different programming,,,,, 2.4 has VVT ( variable valve timing or cam timing ) untill 09 when the 2.2 picked it up even though its a diff head.
2.0 has all different internals and an even smaller bore............ |
Originally Posted by IgottaWoody
(Post 451243)
Originally Posted by an08HHR
(Post 451242)
Use the "Search" function for more in-depth details should you wish.. |
Originally Posted by CrazyCarKid
(Post 451255)
Slightly off topic, but is that why the 2.2 engine is now rated with a slightly better MPG?
Originally Posted by sleeper
(Post 451276)
Yes Bored & Stroked, but also the 2.4 block is beefed up in critical areas in addition to all the other stuff mentioned & not..
Use the "Search" function for more in-depth details should you wish.. I chose the 2.4 for those reasons even tho I would give up some in mpg but felt I got a engine that would hold up much better in the long haul. |
(Post 451295)
Direct injection is the main reason.
Really? I had no idea the 2.2 was a direct injection engine. Source? |
Originally Posted by AmericanMini
(Post 451329)
Really?
I had no idea the 2.2 was a direct injection engine. Source? Engines; • 2.4L I-4 SIDI (Spark Ignition Direct Injection) this is for the GMC's |
2.0 is the only sidi (direct injection) engine in the hhr. 2.4 in the other applications is direct injected, the 6 speed auto.trans is with the 2.4 direct injected motor also.
I'm not sure but for the 09 model year, didn't the 2.2 get Direct Injection ?
I thought I read it here ?? |
